First off -Brand new EFI harness (from concept z) -Old injectors -Old coil packsCylinder 3, 5 and 4 are not firing. I determined this by pulling the connectors to the coil packs and the idle did not change. Injectors are working as far as I can tell (I listened to them with a screw driver and there is fuel on the plugs). The plugs that are firing are COVERED in black soot. I tried swapping coil packs, but the problem doesn't go with the pack, it stays at the cylinder. Does this mean bad wiring?? Its a brand new EFI harness (bought over the summer, just got the engine running a few weeks ago). Could it be the ECU? I know my CAS is good as well as my PTU.
